3f28dsboek
4 years agohelp for Error (170143): Final fitting attempt was unsuccessful
The complier give the following error message
Anyone can tell me how to analyze the error?
I can't figure out the reason of failure in routing from these message
Error (23035 Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
---- where is the location of the report file(s) ?
aoc device/matrix_mult.cl -o bin/matrix_mult.aocx -fp-relaxed -fpc -dont-error-if-large-area-est -no-interleaving=default --board pac_s10_dc
Warning: Command has been deprecated. Please use -board=<value> instead of --board <value>
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Linking Object files....
aoc: Optimizing and doing static analysis of code...
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error: An error occurred during routing
Error: Quartus Prime Fitter was unsuccessful. 2 errors, 452 warnings
Error (293001): Quartus Prime Full Compilation was unsuccessful. 3 errors, 2295 warnings
Error (23035): Tcl error: ERROR: Error(s) found while running an executable. See report file(s) for error message(s). Message log indicates which executable was run last.
Error (23031): Evaluation of Tcl script s10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 9 errors, 2295 warnings
Error (16546): Cannot load final database - ensure all earlier stages of the compiler have completed.
Error (17941): The design could not be loaded due to errors.
Error (23031): Evaluation of Tcl script scripts/adjust_plls_mcp.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 4 errors, 0 warnings
Error: Compiler Error, not able to generate hardware
- ShengN_altera
Below is a similar previous case about Error (170143) for your reference.
May be you have to reduce some code in your kernel in order to solve the congestion issue.
Sheng - 3f28dsboek
Hi Sheng,
In the report only DSP usage is above 25%, so the routing problem should due to DSP.
Does that mean we can never make full use of DSP?
What percentage of DSP is a reasonable design that can be routed?
Thank you very much
- ShengN_altera
Regarding that particular DSP usage question you mentioned above, perhaps you can open a new thread in Intel® High Level Design forum for better confirmation. The link of the forum is provided below.
https://community.intel.com/t5/Intel-High-Level-Design/bd-p/high-level-design
Sheng
