10 years agoHelp Can't open ModelSim on new install
I need to install the free software on a Windows XP machine (32 bit). The latest version requires 64 bit; therefore, I have installed Quartus 13.1 which includes ModelSim-Altera 10.1d. Whe...
10 years agoAh, right you are. Check your path environment variable. Make sure it specifies the modelsim you want to use. If not edit it. Also remove any other modelsim mentions in there.
