17 years ago1) Yes I did see the driver being installed, I mean is there a possibility for the driver not being installed? I got the folder inside the driver folder... called usb-blaster...
2) Yes it does detect the haRdware, and when i try to install it it says ... to put a disk in or rederict to a folder to look in.. so i chose USB-BLaster folder, and it shows installing driver and then it just says an error occured .. couldnt finish installing the driver ... something about the digital signature of the file .. 3) No USB-blaster is not avialable from the drop down list
