17 years agoHi Mastaan
just a few questions.. 1)When you were installing quartus II on your computer, did u notice the driver being installed? 2)When you plug in the USB blaster cable, does your computer detect a new hardware? 3)After you plug in the USB blaster, go to hardware on the upper left of the screen and click on that. Is USB blaster available from the drop down menu. If so, then select it and then try to program? I hope this helps Regards, Joseph
