15 years agohelp:why the ram can't be placed
hi:
I use ep3c120 ,I only use the memory 2815K bit, Total memory bits 2,815,268 / 3,981,312 ( 71 % ) Embedded Multiplier 9-bit elements 350 / 576 ( 61 % ) Total PLLs 2 / 4 ( 50 % ) Error: Can't place all RAM cells in design Info: Selected device has 390 memory locations of type M9K. The current design requires 401 memory locations of type M9K to successfully fit. Info: Memory usage required for the design in the current device: 103% M9K memory block locations required I use the ram type is "auto", I think it can auto combine two memory as a M9K ,but it not . how can I do?
