Altera_ForumHonored Contributor15 years agohelp:why the ram can't be placed hi: I use ep3c120 ,I only use the memory 2815K bit, Total memory bits 2,815,268 / 3,981,312 ( 71 % ) Embedded Multiplier 9-bit elements 350 / 576 ( 61 % ) Total PLLs 2 / 4 ( 50...Show More
Altera_ForumHonored Contributor15 years agohow to use memories efficiently. If you means the analysis or sythesis setting?
Recent DiscussionsCompile option not saved (reversed to default)quartus pro 25.3 bug?SSLC Login Issue – "You need to enroll" loop after OTP verificationflexlm errorQuesta Sim on Windows - linking to external LIBSolved
