helloworld issue on cyclone V
I'm trying to develop using Terasic C5P board, which has Cyclone V FPGA. And host pc is set up with Ubuntu 14.04 and Intel OpenCL 17.1.
My problem is that I cannot program `/root/intelFPGA/17.1/hld/board/c5p/tests/hello_world/bin/hello_world.aocx` via JTAG, although my JTAG usb is correctly connected to my board.
I got a following error message. And I also have tried to set up on CentOS because of this error, but the operation system force reboots during a configuration via JTAG.
root@sada:hello_world $ ./bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1
Querying device for info:
CL_DEVICE_NAME = c5p : HPC Reference Platform
CL_DEVICE_VENDOR = Terasic
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 17.1
CL_DRIVER_VERSION = 17.1
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 1073741824
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 268435456
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = false
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Reprogramming device [0] with handle 1
MMD INFO : [acl0] failed to program the device through CvP.
MMD INFO : executing "quartus_pgm -c 1 -m jtag -o "P;reprogram_temp.sof@1""
Info: *******************************************************************
Info: Running Quartus Prime Programmer
Info: Version 17.1.0 Build 590 10/25/2017 SJ Standard Edition
Info: Copyright (C) 2017 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and its AMPP partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Fri Dec 21 18:57:18 2018
Info: Command: quartus_pgm -c 1 -m jtag -o P;reprogram_temp.sof@1
Info (213045): Using programming cable "C5P [1-2]"
Info (213011): Using programming file reprogram_temp.sof with checksum 0x05EFD99C for device 5CGXFC9D6F27@1
Info (209060): Started Programmer operation at Fri Dec 21 18:57:23 2018
Info (209016): Configuring device index 1
Info (209017): Device 1 contains JTAG ID code 0x02B040DD
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Fri Dec 21 18:57:27 2018
Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 478 megabytes
Info: Processing ended: Fri Dec 21 18:57:27 2018
Info: Elapsed time: 00:00:09
Info: Total CPU time (on all processors): 00:00:02
MMD INFO : [acl0] PCIe-to-fabric read test failed, read 0xffffffff after 1 attempts
mmd program_device: Board reprogram failed
Kernel initialization is complete.
Launching the kernel...
MMD FATAL: acl_pcie.cpp:62: can't find handle -34 -- aborting
host: acl_pcie.cpp:62: ACL_PCIE_DEVICE* get_pcie_device(int): Assertion `0' failed.5 Replies
- HRZ
Does your board pass "aocl diagnose acl0"?
- YSada
Yes it does.
I have doubts about my aocl flash. Is my JTAG USB cable is necessary after aocl flash? I have a experience to set up DE5a Net DDR4 and It wasn't needed.
root@sada:~ $ aocl diagnose acl0 Verified that the kernel mode driver is installed on the host machine. Using platform: Intel(R) FPGA SDK for OpenCL(TM) Using Device with name: c5p : HPC Reference Platform Using Device from vendor: Terasic clGetDeviceInfo CL_DEVICE_GLOBAL_MEM_SIZE = 1073741824 clGetDeviceInfo CL_DEVICE_MAX_MEM_ALLOC_SIZE = 1072693248 Memory consumed for internal use = 1048576 Actual maximum buffer size = 1072693248 bytes Writing 1023 MB to global memory ... Allocated 1073741824 Bytes host buffer for large transfers Write speed: 816.17 MB/s [816.17 -> 816.17] Reading and verifying 1023 MB from global memory ... Read speed: 804.17 MB/s [804.17 -> 804.17] Successfully wrote and readback 1023 MB buffer Transferring 8192 KBs in 16 512 KB blocks ... 553.19 MB/s Transferring 8192 KBs in 8 1024 KB blocks ... 646.89 MB/s Transferring 8192 KBs in 4 2048 KB blocks ... 752.08 MB/s Transferring 8192 KBs in 2 4096 KB blocks ... 791.50 MB/s Transferring 8192 KBs in 1 8192 KB blocks ... 792.19 MB/s PCIe Gen2.0 peak speed: 500MB/s/lane Writing 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 548.95 553.09 536.97 537.99 1048576 638.44 646.89 634.02 631.68 2097152 745.32 752.08 743.03 742.59 4194304 788.59 791.50 785.71 787.58 8388608 792.19 792.19 792.19 792.19 Reading 8192 KBs with block size (in bytes) below: Block_Size Avg Max Min End-End (MB/s) 524288 542.00 553.19 533.15 531.31 1048576 628.96 630.81 625.49 622.37 2097152 721.87 722.43 720.88 719.30 4194304 762.59 762.75 762.43 761.64 8388608 779.54 779.54 779.54 779.54 Write top speed = 792.19 MB/s Read top speed = 779.54 MB/s Throughput = 785.87 MB/s DIAGNOSTIC_PASSED - HRZ
I have never used a PCI-E-attached Cyclone V board but for PCI-E-attached Stratix V and Arria 10 boards, after the initial programming via JTAG to enable the PCI-E core, the JTAG cable will not be required anymore (unless the PCI-E core breaks and JTAG reconfiguration is required again). Since diagnose is passing in your case, PCI-E transfer must be working correctly. However, for some reason, run-time FPGA reconfiguration seems to be going through JTAG instead of PCI-E. Unless Cyclone V does not support PCI-E-based reconfiguration, this should not happen.
- songweiren
I meet the same issue, can you tell me how to slove the problem ? Thank you in advance.
- songweiren
How do you solve the problem? I meet the same problem. Thank you in advance
