8 years ago
helloworld issue on arria10Gx development kit
I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong doing.
user@user:~/opencl_examples/hello_world$ bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) OpenCL
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 2.0
Querying device for info:
CL_DEVICE_NAME = Intel(R) Core(TM) i7-6800K CPU @ 3.40GHz
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 32902
CL_DEVICE_VERSION = OpenCL 2.0 (Build 475)
CL_DRIVER_VERSION = 1.2.0.475
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 262144
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 64
CL_DEVICE_GLOBAL_MEM_SIZE = 16734322688
CL_DEVICE_IMAGE_SUPPORT = true
CL_DEVICE_LOCAL_MEM_SIZE = 32768
CL_DEVICE_MAX_CLOCK_FREQUENCY = 3400
CL_DEVICE_MAX_COMPUTE_UNITS = 12
CL_DEVICE_MAX_CONSTANT_ARGS = 480
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 131072
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 1024
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 128
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 1
Command queue out of order? = true
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Context callback: clCreateProgramWithBinary failed
ERROR: CL_INVALID_BINARY
Failed to create program with binary
Steps I followed are :
1. Installed and setup Intel OpenCL SDK for FPGA.
2. Configured Arria10Gx development kit as per instructions specified in document
https://www.altera.com/en_us/pdfs/literature/an/an807.pdf
3. compiled OpenCL kernel with below command and generated hello_world.aocx file.
aoc device/hello_world.cl -o bin/hello_world.aocx -board a10gx
4. compiled host program with make command
5. used "bin/host" command to run host program.
Also here is the info about detected devices
user@user:~/opencl_examples/hello_world$ aoc -list-boards
Board list:
a10gx
Board Package: /home/mobiliya/intelFPGA_pro/17.1/hld/board/a10_ref
a10gx_hostch
Channels: host_to_dev, dev_to_host
regards
Vinod
    Does "aocl diagnose" pass? If not, you should repeat the process of initializing the board until aocl diagnose passes.
    Hi vinodk,
    I work on the same topic like you and I have a compilation issue.
    When I try to compile the kernel hello_world.cl (aoc device\hello_world.cl -o bin\hello_world.aocx -board=a10gx) I get the next error:
    Error: The following files were not archived
    Error: ERROR: Archiver failed because there were no files to archive
    Error: Failed to generate 'base_bak.qar'
    Error (23031): Evaluation of Tcl script c:/intelfpga_pro/17.1/quartus/common/tcl/apps/qpm/qar.tcl unsuccessful
    Error: Quartus Prime Shell was unsuccessful. 7 errors, 0 warnings
    Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
    Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
    Error: Compiler Error, not able to generate hardware
    I do not know what could be the problem. Searching on the Board documentation I fount this:
    Attention:
    The native Arria 10 GX FPGA Development Kit does not automatically work with the SDK. Before using the Arria 10 GX FPGA Development Kit with the SDK, you must first contact your field applications engineer or regional support center representative who will configure the development kit for you.
    Could you help me with this issue please?
    Thank you!
    --- Quote Start ---
    --- Quote End ---
    Hi HRZ,
    Now "aocl diagnose" does not work. So tried to repeat the setup process to make aocl diagnose to pass. However got stuck again while programming top.sof (of a10_ref_initialization.tgz package)file to board.
    mobiliya@mobiliya:~/temp$ sudo killall jtagd
    mobiliya@mobiliya:~/temp$ sudo jtagconfig
    1) USB-BlasterII [3-5]
    02E660DD 10AX115H1(.|E2|ES)/10AX115H2/..
    020A40DD 5M(1270ZF324|2210Z)/EPM2210
    mobiliya@mobiliya:~/temp$ quartus_pgm -c 1 -m JTAG -o "p;max5_150.pof@2"
    Info: *******************************************************************
    Info: Running Quartus Prime Programmer
    Info: Version 17.1.0 Build 240 10/25/2017 SJ Pro Edition
    Info: Copyright (C) 2017 Intel Corporation. All rights reserved.
    Info: Your use of Intel Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Intel Program License
    Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
    Info: the Intel FPGA IP License Agreement, or other applicable license
    Info: agreement, including, without limitation, that your use is for
    Info: the sole purpose of programming logic devices manufactured by
    Info: Intel and sold by Intel or its authorized distributors. Please
    Info: refer to the applicable agreement for further details.
    Info: Processing started: Tue Mar 20 10:27:54 2018
    Info: Command: quartus_pgm -c 1 -m JTAG -o p;max5_150.pof@2
    Info (213045): Using programming cable "USB-BlasterII [3-5]"
    Info (213011): Using programming file max5_150.pof with checksum 0x00908D89 for device 5M2210ZF256@2
    Info (209060): Started Programmer operation at Tue Mar 20 10:27:55 2018
    Info (209017): Device 2 contains JTAG ID code 0x020A40DD
    Info (209018): Device 2 silicon ID is ALTERA10-6
    Info (209044): Erasing MAXII/MAXV configuration device(s)
    Info (209023): Programming device(s)
    Info (209021): Performing verification on device(s)
    Info (209011): Successfully performed operation(s)
    Info (209061): Ended Programmer operation at Tue Mar 20 10:28:00 2018
    Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings
    Info: Peak virtual memory: 422 megabytes
    Info: Processing ended: Tue Mar 20 10:28:00 2018
    Info: Elapsed time: 00:00:06
    Info: Total CPU time (on all processors): 00:00:01
    mobiliya@mobiliya:~/temp$ quartus_pgm -c 1 -m JTAG -o “p;top.sof”
    Error (213008): Programming option string "“p" is illegal. Refer to --help for legal programming option formats.
    top.sof”: command not found
    Tried to program top.sof using quartus programmer( GUI utility) however failed at next step to program boardtest.aocx. Command "aocl list-devices" does not lists the board.
    mobiliya@mobiliya:~/temp$ aocl flash acl0 boardtest.aocx
    aocl flash - Initialize the FPGA with a specific startup configuration.
    Usage: aocl flash <device_name> <file.aocx>
    Supply the .aocx file for the design you wish to set as the default
    configuration which is loaded on power up.
    Description:
    This command initializes the board with a default configuration
    that is loaded onto the FPGA on power up. Not all boards will
    support this, check with your board vendor documentation.
    aocl list-devices
    Warning:
    No devices attached for package:
    --- Quote Start ---
    Hi vinodk,
    Attention:
    Thank you!
    --- Quote End ---
    I think you need to follow HRZ's recommendation of openCL setup guide.
    --- Quote Start ---
    --- Quote End ---
    It seems you copy/pasted the command from somewhere (a PDF or Word file?) and an incorrect quotation mark (“ instead of ") was pasted in your command line. Try rerunning the command using the correct quotation mark.
