8 years agohelloworld issue on arria10Gx development kit
Hi, I am trying to compile and run hello_world example of OpenCL SDK on Arria10Gx development board. Example fails to run with below error code. kindly check below steps and comment on any wrong...
8 years ago --- Quote Start --- mobiliya@mobiliya:~/temp$ quartus_pgm -c 1 -m JTAG -o “p;top.sof” Error (213008): Programming option string "“p" is illegal. Refer to --help for legal programming option formats. top.sof”: command not found mobiliya@mobiliya:~/temp$ Tried to program top.sof using quartus programmer( GUI utility) however failed at next step to program boardtest.aocx. Command "aocl list-devices" does not lists the board. --- Quote End --- It seems you copy/pasted the command from somewhere (a PDF or Word file?) and an incorrect quotation mark (“ instead of ") was pasted in your command line. Try rerunning the command using the correct quotation mark.
