9 years agoHello_world doesn't work for Arria 10 ubuntu 14.04
1. quartus 17.0, ubuntu 14.04, opencl 2. Arria10 is used. 3. all diagnose pass. command: aoc device/hello_world.cl -o bin/hello_world.aocx --board a10gx Error message in hello_world....
9 years ago --- Quote Start --- To be honest I am not sure. I only know how to force the flat flow, I have no idea how to force the PR flow. The PR flow has always been the default flow and on my environment, the compiler still seems to default to that flow even with 17.0.2. I checked altera's documents again for v17, there is no mention of the flat flow. Even though this flow has existed for a long time, it was never documented, but they seem to have changed something in v17.0.2. Assuming that aoc accepts the "--bsp_flow" switch, I think you should probably use "--bsp_flow top" rather than "base" for the standard PR flow, but I could be wrong. Regarding the board being connected or not, compilation does not require the board to be present and whether the board is present or not should not make any difference in this case. --- Quote End --- I tried compiling one of Intel design examples with "--bsp_flow top" and I am still receiving the same errors.
