9 years agoHello_world doesn't work for Arria 10 ubuntu 14.04
1. quartus 17.0, ubuntu 14.04, opencl 2. Arria10 is used. 3. all diagnose pass. command: aoc device/hello_world.cl -o bin/hello_world.aocx --board a10gx Error message in hello_world....
9 years ago --- Quote Start --- I just tested v17.0.2 on my own environment. The standard PR (Partial Reconfiguration) flow works fine, but the flat flow is indeed broken. I get the same error as everyone else. Still, the default flow should be the PR flow and I am wondering why you guys are being defaulted to the flat flow. I will open a support request with Altera. --- Quote End --- HRZ, thanks for an answer and the tip. Still wondering how to force/set explicitly that PR flow? Currently trying --bsp_flow base command and wating for results. Am I on the right track? Also, is it possible that flat flow is defaulted because I don't have an actual board plugged in?
