9 years agoHello_world doesn't work for Arria 10 ubuntu 14.04
1. quartus 17.0, ubuntu 14.04, opencl 2. Arria10 is used. 3. all diagnose pass. command: aoc device/hello_world.cl -o bin/hello_world.aocx --board a10gx Error message in hello_world....
9 years agoMake sure you are using the same version of Quartus and AOC (quartus_map --version and aoc --version should return the same number). Also unless you are using Altera's reference Arria 10 board, you should not be using Quartus/AOC v17.0.2, and instead use the version that matches your board's BSP version.
