Hello, I am writing a verilog code from my DE10-Lite Board to scroll the a word or number but keep having errors. Would you be able to help?
Thank you sstrell for check my code. Can I confirm this code?
//////////////////// SCROLLING DE10 ////////////////////////////////
module DE10_LITE_Default(
input clock, reset,
input HEX0, HEX1, HEX2, HEX3, //the 4 inputs for each display
output a, b, c, d, e, f, g, dp, //the individual LED output for the seven segment along with the digital point
output [3:0] an // the 4 bit enable signal
localparam N = 18;
reg [N-1:0]count; //the 18 bit counter which allows us to multiplex at 1000Hz
reg [6:0]sseg; // NEW CODE
always @ (posedge clock or posedge reset)
begin
if (reset)
count <= 0;
else
count <= count + 1;
end
reg [6:0]sseg_temp; //the 7 bit register to hold the data to output ==== Changed from 'reg' ====
reg [3:0]an_temp; //register for the 4 bit enable
always @ (*)
begin
case(count[N-1:N-2]) //using only the 2 MSB's of the counter
2'b00 : //When the 2 MSB's are 00 enable the fourth display
begin
sseg = HEX0;
an_temp = 4'b1110;
end
2'b01: //When the 2 MSB's are 01 enable the third display
begin
sseg = HEX1;
an_temp = 4'b1101;
end
2'b10: //When the 2 MSB's are 10 enable the second display
begin
sseg = HEX2;
an_temp = 4'b1011;
end
2'b11: //When the 2 MSB's are 11 enable the first display
begin
sseg = HEX3;
an_temp = 4'b0111;
end
endcase
end
assign an = an_temp;
reg [6:0] HEX_Display; // 7 bit register to hold the binary value of each input given
always @ (*)
begin
case(sseg)
4'd0 : HEX_Display = 7'b0111111; //to display dash
4'd1 : HEX_Display = 7'b0000001; //to display 0
4'd2 : HEX_Display = 7'b1001111; //to display 1
4'd3 : HEX_Display = 7'b0110000; //to display E
4'd4 : HEX_Display = 7'b1000010; //to display d
4'd5 : HEX_Display = 7'b0111111; //to display dash
//4'd6 : sseg_temp = 7'b0000010; //to display 6
// 4'd7 : sseg_temp = 7'b1111000; //to display 7
// 4'd8 : sseg_temp = 7'b0000000; //to display 8
//4'd9 : sseg_temp = 7'b0010000; //to display 9
//default : sseg_temp = 7'b0111111; //dash
endcase
end
assign {g,f,e,d,c,b,a} = HEX_Display; // CHANGED FROM THIS assign HEX_Display = {g, f, e, d, c, b, a} ;
//concatenate the outputs to the register, this is just a more neat way of doing this.
// I could have done in the case statement: 4'd0 : {g, f, e, d, c, b, a} = 7'b1000000;
// its the same thing.. write however you like it
assign dp = 1'b1; //since the decimal point is not needed, all 4 of them are turned off
endmodule
COMPILING RESULTS;
Info (12021): Found 3 design units, including 3 entities, in source file project c hex display.v
Info (12023): Found entity 1: part1
Info (12023): Found entity 2: mux_3bit_5to1
Info (12023): Found entity 3: char_7seg
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(21) near text: "wire"; expecting a direction.
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(74) near text: "assign"; expecting "endcase".
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(74) near text: '.
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(148) near text: ")"; mismatched closing parenthesis .
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(162) near text: "}"; expecting ":", or ",".
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(162) near text: "{"; expecting "}".
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(181) near text: "assign"; expecting an operand.
Error (10170): Verilog HDL syntax error at Shift code, modified but not working yet.v(185) near text: "endmodule"; expecting "endcase".
Info (12021): Found 0 design units, including 0 entities, in source file shift code, modified but not working yet.v
Info (144001): Generated suppressed messages file C:/Users/ceedwards/Downloads/Quartus files downloaded/DE10_LITE_Default ADD CODE to CODE STRUCTURE_project/PROJECT C HEX Modified_restored/top.map.smsg
