13 years agoHi jacklsw and FvM
so this is working (sufficiently for my purpose) I went down jacklsw route (mostly because in my post I did ask 'Am I trying to do too much in each of the states, should I be creating some other code to do the donkey work?' :rolleyes: s but I do think FvM is (part of) the more formal way to write this sort of stuff, So I guess, my working code (below-- yes, is still a bit scruffy, but its not getting released into the wild, its my test) might be called a three process state machine? Or is it really two process, as the third is doing work rather than managing? Any comments on the code are welcome, and indeed gratefully recieved, if you have the time to look, (note added InterFrameDelay to sensitivity list - Im pretty sure that just a simulation thing, and it would work 'in the real world' without it Thanks so much (again) Pete B begin process (nReset,Clock50) begin if (nReset ='0') then CurrentState <= InReset; elsif (rising_edge (Clock50)) then CurrentState <= NextState; end if; end process; process (CurrentState,InterFrameDelay) begin case CurrentState is when InReset => NextState <= StartCol; when StartCol => NextState <= WriteFreq; when WriteFreq => NextState <= StrobeOff; when StrobeOff => if (CurrentFreqBin="00000") then NextState <= ColumnFinished; else NextState <= WriteFreq; end if; when ColumnFinished => NextState <= ColFinStrobeOff; when ColFinStrobeOff => if (index = 256) then NextState <= AllDone; else NextState <=StartCol; end if; when AllDone => NextState <= AllDoneLoop; when AllDoneLoop => if interFrameDelay<"000000000000000000000010") then NextState <= AllDone; else NextState <= AllDoneLoop; end if; end case; end process; --------------------------------------------------------------------------- process (CurrentState,Clock50) begin if (Rising_edge (Clock50)) then case CurrentState is when InReset => CurrentFreqBin<="00000"; TargetBin<="00000"; TargBinInt<=0; index <= 0; InterFrameDelay<="000000000000000000000000"; ------------------------ when StartCol => TargBinInt<=FreqTable(index); TargetBin <= std_logic_vector(to_unsigned(TargBinInt,5)); ----------------------- when WriteFreq => FreqSlot<=CurrentFreqBin; if (CurrentFreqBin=TargetBin) then Amplitude<="11111111"; else Amplitude<="00000000"; end if; Strobe<='1'; ---------------------- when StrobeOff => Strobe<='0'; CurrentFreqBin<=CurrentFreqBin+1; ------------------------ when ColumnFinished => ColumnDone<='1'; index<=index+1; ------------------------ when ColFinStrobeOff => if (index = 256) then ColumnDone<='1'; else ColumnDone<='0'; end if; ------------------------ when AllDone => InterFrameDelay <="000000000000000000100000"; ColumnDone<='1'; ------------------------ when AllDoneLoop => ColumnDone<='0'; InterFrameDelay <=InterFrameDelay-'1'; ------------- end case; end if; end process;
