13 years agoThe latch issue is brought up by assigning other signals than NextState in the asynchronous process, and assigning them only in some of the states. Besides generating a lot of warnings, you can be rather sure that constructs like "index<=index+1;" will never work based on latches.
A simple solution, although not usually suggested in the text books is to change the design to a single synchronous process state machine, simply merging both processes.
