11 years agoHC-SR04 (ultrasonic sensor) verilog code help
Hi, for my project i have to interface the HC-SR04 (ultrasonic sensor) to my DE2-115 board. I have been struggling with the verilog code for a while. Can anyone please help me out with the code? T...
11 years ago --- Quote Start --- If you can post the errors as well we can help you better. And I don't know much about verilog but isn't <= a VHDL thing, and does Verilog use assign? --- Quote End --- Well i have gotten no compilation errors now (had to fix a few here and there) but now the problem is i need to write a synthesizable code. I'm not sure if u have that kind of thing in VHDL. N yes Verilog uses assign and "<=" is an unblocking statement for verilog which basically means "=". Coming back to the synthesizable part, assign distance_o = (dist_counter * 340/2) I cant use division. How else can i do this?
