Has anybody seen this error? And if so, what is being done to correct this?
Sorry for the inconveniences caused.
Can you please attache the log/report. (Click on preview report)
Also please do check with Quartus 19.1 pro.
Anand
- AnandRaj_S_Intel7 years ago
Hi Mark,
Thanks for sharing report,
Please share the project If possible, Which will help in replicate the issue.
Anand
- MSchu87 years ago
Hi Anand, I cannot share my projects. They are proprietary. As for the failure, you can cause it by scanning a JTAG chain that contains a 64Mbit device. You do not have to be running a specific project for this to occur. I had also attached the crash reports. Are they of any help? Regards. Mark - AnandRaj_S_Intel7 years ago
Hi Mark,
Please give me some time, i will check with quartus 19.2 pro and update you.
Anand
Hi Mark,
Just created a simple project with Quartus 19.1 pro for Arria 10 soc Development kit having EPCQL1024 flash device.
I was able to scan the jtag chain and program both sof/jic file successfully, Also change or view the Devices and Pins option.
Please try with Quartus 19.1pro.
Anand
- MSchu87 years ago
Hi Anand, The programmer problem occurs with a 64Mbit device. I am seeing the issue when using EPCS64, EPCQ64 and EPCQ64A. Regards. Mark - AnandRaj_S_Intel7 years ago
Hi Mark,
Apologies for the inconvenience caused, Presently we don't have any kit with 64Mbit flash.
Can you make a video of the issue and attach with latest Quartus version.
So that i can transfer case to next level.
Anand
- MSchu87 years ago
Hi Anand, Video attached. It may possibly be the worst video ever, but I think you can see it well enough. In the video, I have reproduced the failure in both 18.1 Pro and 17.1 Standard. I can recreate this failure in other versions as well. It is very simple to repeat – JTAG scan a chain that contains an EPCS64, EPCQ64 or EPCQ64A and you will see the problem. Regards. Mark
