14 years agohandling with differential signals in quartus II
Hi at all,
I have a generel question about handling with differential signals in quartus II. Is it necessary to create two pins (p and n) in schematic for a differential signal or is it usual to use one pin and define the signal as differential (e.g. as LVDS) in pin planner? In this case the pin planner creates the related negative signal. When I compile my design with one pin quartus reports a warning that quartus automatically generates the negative pin. because of the warning it seems that this approach is not the normal way. I hope there is someone who can explain the correct handling with differential signals. best regards occino
