8 years agoHandle error:"Connected system ID hash not found on target at expected base address"
Hi , I get the following error while trying to run C file on fpga using eclipse: "Connected system ID hash not found on target at expected base address" (scrrenshot is attached with name lasterror...
8 years agoedit:This is a response for the first comment, now checking the suggestion in the first comment.Thank you , I'm trying a simple program is saw online:
" module my_first_niosii ( CLOCK_50, LEDR ); input CLOCK_50; output [9:0] LEDR; NEEK10_QSYS u0( .clk_clk (CLOCK_50), . reset_reset_n (1'b0), . pio_led_external_connection_export (LEDR) ); endmodule " ";(this line :". reset_reset_n (1'b0 ";( used to be :". reset_reset_n (1'b1 but I still get the same problem.. Thanks.
