8 years agoHandle error:"Connected system ID hash not found on target at expected base address"
Hi , I get the following error while trying to run C file on fpga using eclipse: "Connected system ID hash not found on target at expected base address" (scrrenshot is attached with name lasterror...
8 years agoHi,
I have faced the same problem and it was because of reset problem. In design, I have used a switch for reset and by default, it was active so FPGA was not able to load the elf. Can you check the reset switch state and take care of whether reset is active low and active high Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
