10 years agoGuidelines to avoid Negative Slack with State Machines
I m working on a hardware which uses a hardware block (Lets call it x), which does communication with a host machine, does processing based on the request given by the host machine, and gives a response back once the processing is done. X hardware is written as a state machine, with a total of 54 usable states. The coding is done as follows(Just a sample demonstration, exactly the way state machine is defined in my hardware) always@(posedge clk) begin if(rst) presentstate <= IDLE; else begin presentstate <= nextstate; case(nextstate) IDLE: STATE1: STATE2: STATEX: default: endcase end end always@(*) begin nextstate = presentstate; case(presentstate) IDLE: begin if(condition1) nextstate = STATE1; end STATE1: begin if(condition2) nextstate = STATE2; else if(condition3) nextstate = STATEX; else nextstate = IDLE; end STATE2: nextstate = STATEX; STATEX: nextstate = IDLE; endcase end The states are defined using localparam, and are defined in a binary encoded fashion(But QuartusMap report says, the encoding was done as onehotcode) localparam IDLE = 0; localparam STATE1 = 1; This hardware is consistently showing negative slacks after routing, with launch clock and latch clock being the same, and the from node and the to node, both within the hardware x.Some of the incoming signals and some of the outgoing signals are not latched(To save a clock cycle). But with the To Node and From Node within the same hardware, Will latching the signals make a difference in the timing? Is there anything wrong with the way, the coding is done? Any suggestions on how to get rid of the negative slack?. When you get a negative slack in the route report, how do you systematically debug it?. The route report shows long combinational path in terms of the net names generated in the synthesis, and how would you relate it to your code?. Regards Jeebu
Thanks a lot @josyb and @rsefton for your inputs.
@josyb: Thanks for sharing your VHDL code. Just a doubt to clear in verilog/VHDL. I see that the outputs are driven within the nextstate logic, and not in synchronous block(@(posedge clk)). I see in the josyb's coding that in the nextstate process() block, you have specified finite number of signals in the sensitivity list. But lets say in a similar scenario in verilog, we have the nextstate always@(*) block , and in presence of any asynchronous input signals, wont the output get corrupted. Is this a safe way of coding(Driving output in the nexstate logic)?. Have gone through CliffordCummings paper http://www.sunburst-design.com/papers/cummingssnug2003sj_systemverilogfsm.pdf (http://www.sunburst-design.com/papers/cummingssnug2003sj_systemverilogfsm.pdf). Can anyone of you share some content/experience on different coding styles(preferrable verilog) and the hardware(Altera Specific) inferred with each case. Regards Jeebu
