10 years agoGuidelines to avoid Negative Slack with State Machines
Hi, I m working on a hardware which uses a hardware block (Lets call it x), which does communication with a host machine, does processing based on the request given by the host machine, and gi...
10 years agoThanks a lot @josyb and @rsefton for your inputs.
@josyb: Thanks for sharing your VHDL code. Just a doubt to clear in verilog/VHDL. I see that the outputs are driven within the nextstate logic, and not in synchronous block(@(posedge clk)). I see in the josyb's coding that in the nextstate process() block, you have specified finite number of signals in the sensitivity list. But lets say in a similar scenario in verilog, we have the nextstate always@(*) block , and in presence of any asynchronous input signals, wont the output get corrupted. Is this a safe way of coding(Driving output in the nexstate logic)?. Have gone through CliffordCummings paper http://www.sunburst-design.com/papers/cummingssnug2003sj_systemverilogfsm.pdf (http://www.sunburst-design.com/papers/cummingssnug2003sj_systemverilogfsm.pdf). Can anyone of you share some content/experience on different coding styles(preferrable verilog) and the hardware(Altera Specific) inferred with each case. Regards Jeebu
