10 years agoGuidelines to avoid Negative Slack with State Machines
Hi, I m working on a hardware which uses a hardware block (Lets call it x), which does communication with a host machine, does processing based on the request given by the host machine, and gi...
10 years ago --- Quote Start --- Your state machine coding looks fine to me, although I don't care for the split combinational nextstate with registered presentstate style any more. There was a day when synthesis tools needed the help of that coding style, but modern tools don't need it and I find it a bit archaic. I know a lot of books still push that style, but don't believe everything you read. Bob --- Quote End --- A two- or a three-process state machine is the better approach, unless you have something simple that fits perfectly in the synchronous process. Back to the main issue: if a state machine is failing timing there are 2 possibilities:
- the required clock frequency is simply too high
- there is too much decision logic in the state transitions
