10 years agoGui vs. Quartus command-line exectuables
When I run a command-line script such as quartus_map and it completes successfully, I would expect that when I open the project in the gui and run the fitter, quartus would detect that map has alread...
10 years agoProbably, but you should have a simple workaround. Like I said, I would be surprised if this flow gets used/tested much, so doubtful others have run into it. Please file a Service Request so it can be fixed.
