10 years agoGui vs. Quartus command-line exectuables
When I run a command-line script such as quartus_map and it completes successfully, I would expect that when I open the project in the gui and run the fitter, quartus would detect that map has alread...
10 years agoNot sure of the exact answer and please file an SR, as it seems like a problem that the fitter doesn't detect this. (I'm guessing this flow isn't tested, as command line users tend to stay in command line).
That being said, I am guessing you're running the fitter from the Task Manager on the left. I close this down and never use it, as it tries to be smart and figure out if something needs to be re-run. If you go to Processing -> Start -> Fitter, there are no "smarts" and it runs the fitter, just like if you ran it from a script. If there was a problem with synthesis and the fitter can't be run, you get an error and it says to re-run synthesis, but if you already have it should just work.
