9 years agoGPIO voltage frequency does not match PLL clock output
I am using a DE0 Nano, which has a 50MHz clock. In Quartus, this clock is the input to a PLL which has an output clock frequency of 1000MHz. This compiles. The clock is input to Verilog code that sends an alternating 1 and 0 bit to a GPIO pin on the clock's rising edge. When I examine the voltage output on the scope I get a square wave with a frequency of 375kHz. Why is this?
How can I ensure that the output on the GPIO has the same frequency as my PLL clock? If this is a hardware issue, what is an Altera board that has GPIO pins that can support voltage frequencies at 200MHz or above? The higher the better. Here is my Verilog Code: module code(input clock, output reg sig); `define PKTLEN 8 localparam PKTLEN = `PKTLEN; reg [0:PKTLEN-1] mag = `PKTLEN 'b10101010; reg [31:0] i = 0; always@(posedge clock) begin sig = mag[i]; if (i < PKTLEN-1) begin i = i+1; end else begin i=0; end end endmoduleNo RepliesBe the first to reply
