16 years agoGPIO pin questions
Hi, I am quite new with Altera's DE2 board and am programming with verilog. I want to know if it is possible to use the jp1/jp2 pins on the board as inputs to trigger an event. Say a switch to turn on one of the board's LED.
I followed the pin assignments on the manual and it works for output but having problems getting inputs to work. Can someone help me with this issue? Thanks.
