9 years agoGot CL_INVALID_BINARY error when emulated HelloWorld example on Windows
I followed the "aocl_getting_started.pdf" instruction to implement the hello_world example on Window. But I got error message about CL_INVALID_BINARY when I tried to run the emulator. The st...
9 years agoApparently the "env" command does not work on windows, but the "set" command should. Can you post the output of the command window when you first run "set CL_CONTEXT_EMULATOR_DEVICE_ALTERA=1" and then the host code?
