8 years agoGetting the PRE_FLOW_SCRIPT_FILE thing to work
Folks, I have been trying to get a tcl script to run before compile to no avail. I have a tcl script to create a vhd file with the build date and time in it, gleaned from the examples on the ...
8 years agoYou are correct! Literally one minute before you posted this, I discovered just that. I was fooling around with signal tap and hit the compile button. It ran the entire compile flow, starting with my pre-compile script.
And thats the answer.... --- Quote Start --- Ed, I don't know for sure but I don't think the pre-flow is executed with A&S. You need to do a full compile. At least that is how it works for me on Q17. --- Quote End ---
