8 years agoGetting the PRE_FLOW_SCRIPT_FILE thing to work
Folks, I have been trying to get a tcl script to run before compile to no avail. I have a tcl script to create a vhd file with the build date and time in it, gleaned from the examples on the ...
8 years agoVikas,
Thanks for responding. The link you referred to is the one I used initially to set up my build date idea. What is is missing is the command in the .qsf to get the synth_preflow.tcl running. This is specifically called out in the Quartus II handbook v 13.1 on page 3-10. It sez to put the set_global_assignment line in the projects .qsf, which I did. There are other links on the web for doing this and they all appear to have the same procedure, which I followed I experimented with the location of the .tcl file but got nowhere. Right now it is at the project top. I added a post_message line in it but I never see anything come out on the messages window. I intentionally misspelled a command in the .qsf file and qts found that immediately. It must be have a settings cache because it "reverted" the qsf settings and wrote them back to the qsf file. I put an error in my build_date.tcl file and there is never a complaint when I run A&S. I dont think qts is even processing the command in the qsf file. I tried restarting qts, does not run the script Its like the PRE and POST script running is disabled... Questions: How do I list the current working directory in the tcl console? ls and dir dont work. There doesnt seem to be a solution for this on the web either. Is this function removed from the quartus tcl implementation? Thanks, Ed --- Quote Start --- Hi, Refer the following old thread especially “readme.txt” as reference, https://www.alteraforum.com/forum/showthread.php?t=46559 It is probably useful as you might be looking for. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation) --- Quote End ---
