Getting Synthesis Error due to undefined Macros In quartus pro 18.0
Hi, Observing an error in quartus,
Info: *******************************************************************
Info: Running Quartus Prime Synthesis Info: Version 18.0.0 Build 219 04/25/2018 Patches 0.06 SJ Pro Edition
Info: Processing started: Wed Mar 25 05:18:11 2020
Info: Command: quartus_syn --read_settings_files=on --write_settings_files=off for_generate -c for_generate Info: qis_default_flow_script.tcl version: #1
Info: Initializing Synthesis... Info: Project = "for_generate"
Info: Revision = "for_generate" Info: Analyzing source files
Critical Warning(13432): Verilog HDL Compiler Directive warning at for_gen.sv(19): text macro "ONE" is undefined
Error(13411): Verilog HDL syntax error at for_gen.sv(19) near text ; Error(13363): Verilog HDL error at for_gen.sv(23): module "for_gen" ignored due to previous errors
Error: Flow failed: Error: Quartus Prime Synthesis was unsuccessful. 3 errors, 1 warning
Code:
module for_gen
#(parameter SIZE = 8) ( input [SIZE-1:0] gray, output [SIZE-1:0] bin ); localparam bit ON=1'b0;
genvar gi; // generate and endgenerate is optional generate
for (gi=0; gi<SIZE; gi=gi+1) begin : genbit
if(ON == 1'b1) begin
assign bin[gi] = ^gray[SIZE-1:gi]; // Thanks Dhruvkumar! end else begin assign bin[gi] = `ONE;
end
end
endgenerate
endmodule
I have declared `ONE in one of the include file and its part of project added in qsf as
set_global_assignment -name VERILOG_INCLUDE_FILE "/nfs/site/disks/dcsg_0041/sumukhbn/for_generate/include/for_gen_inc.vh"
But why still I am seeing this error?
Please resolve as soon as possible
- sstrell
I think you need a `include in your code. The assignment includes the file in your Quartus project but I don't think that lets your for_gen code refer to it.
#iwork4intel
- Sumukh_B_Intel
I don't want add `include, because design is huge its very difficult to add manually.
Please provide me an alternative solution so that it should not disturb RTL files.
- sstrell
I'm pretty sure that's your only solution. There's no way to make your code reference something in another file without an actual reference. Or you could add the `ONE macro to this file, but if you don't want to edit the code, I'm not sure what you can do.
#iwork4intel
- Sumukh_B_Intel
Below link mentioned, we can avoid `include <*.vh> But thats not working . Please check.
https://forums.intel.com/s/question/0D50P00004MgL0PSAV/is-there-a-way-to-include-file-with-macros-and-small-modules-without-having-to-use-include-in-every-file
- KhaiChein_Y_Intel
In the link provided, the code itself can pass compilation with and without 'include "macro.v" becuase it doesnt use the content defined in macro.v in the and_op.v.
The Intel Quartus Prime Pro Edition synthesis uses a different method to define the compilation unit. It follows the Single-file compilation unit (SFCU) method to select compilation unit files. In SFCU, each file is a compilation unit. Items visible only in the compilation-unit scope include macros, global declarations, and default net types. Therefore, you have to add `include in the main.v file.
KhaiY
- Sumukh_B_Intel
You are right, in the image attached include file is not required but if you read the explanation below 2 lines are mentioned.
- We need to add the include (macro)files to the project and just compile for Quartus STD & LITE.
- For Quartus Pro, the compiler to search for macro file and include it during the compile process. No need to use `include in Verilog module. Please check the attached image
Similar to this I found one more query related to this
https://forums.intel.com/s/question/0D50P00003yyT6uSAE/unable-to-synthesize-the-design-with-macros-and-header-files-due-to-undefined-macros?language=en_US
please check on this.
It will be good if you can come back on solution as soon as possible.
- Sumukh_B_Intel
and also right in other compilers like synplify it doesn't expect `include.
SEARCH_PATH will able to resolve these type of issues. So, I felt there should be some solution in quartus.
Please review this as soon as possible.
- KhaiChein_Y_Intel
You may refer to the Intel Quartus Prime Pro Edition Getting Started User Guide (Chapter 5.4.1) https://www.intel.com/content/www/us/en/programmable/documentation/spj1513986956763.html#jbr1442966691310. This chapter states that
Items visible only in the compilation-unit scope include macros, global declarations, and default net types. The contents of included files become part of the compilation unit of the parent file. Modules, primitives, programs, interfaces, and packages are visible in all compilation units.
Therefore, you have to use 'include for macro.
Best regards
KhaiY
- KhaiChein_Y_Intel
Upon checking with the team, you can define maco in the Compiler Settings by clicking on Assignments > Settings > Compiler Settings > Verilog HDL Input
KhaiY
- Sumukh_B_Intel
This is not my requirement.
My requirement is I need to add a include file to project instead of `define. In your solution I need to define Individual macros manually.
In my project there are lot of include files each contain lot macros so I can't declare each macro like that its a tedious process.
Sumukh B N
- KhaiChein_Y_Intel
I have provided a suggestion to work around this offline. Please let me know if it doesnt work.
KhaiY
- Sumukh_B_Intel
After adding below statement this in my sample project qsf i created to reproduce the issue, I am not seeing the error.
set_global_assignment -name VERILOG_CU_MODE MFCU
Let me integrate it to my original project. Thanks for your support.
Sumukh B N
