11 years agoGetting a comparator out of an ALM in arithmetic mode
So I am trying to get an adder/subtractor/comparator out of an ALM. According to the documentation I've seen, the ALM has a 4-input and 3-input LUT available before each full adder. There are two of these 4LUT+3LUT+adder pairs per ALM, which must use at most up to 8 inputs, with at least 4 shared.
This is the logic I am trying to fit into the ALM: s_nota <= (others => r_nota); s_notb <= (others => r_notb); s_eq <= (others => r_eq); s_widea(r_rega'left+2) <= '0'; s_wideb(r_rega'left+2) <= '0'; s_widea(r_rega'left+1 downto 1) <= s_nota xor r_rega xor (r_regb and s_eq); s_wideb(r_rega'left+1 downto 1) <= s_notb xor (r_regb and not s_eq); s_widea(0) <= '1'; s_wideb(0) <= r_cin; s_widex <= std_logic_vector(unsigned(s_widea) + unsigned(s_wideb)); Here r_rega and r_regb are the vectors to be added/compared. r_nota, r_notb, r_eq, r_cin are global registers for the whole process. With a circuit like the above, I get: add, sub, compare less than, compare less than equal, compare equal, etc. just by changing the control lines. However, quartus refuses to put this into a single adder chain. Instead it splits out the s_widea into another ALM. Why? How can I force it to do what I want? This circuit is on the critical path of my design, and my experiments with the design explorer (cutting r_eq) show an 8% gain in fMAX if quartus would pack it as I intended. The e_eq and r_not[ab] are 3 shared signals for both halves of the ALM. The r_reg[ab] are 2 bits for each half. So AFAICT it should fit! Am I wrong? Is there an alternative circuit that does fit and achieves the same goal? Thanks!1 Reply
Just for reference, here are the control line settings:
a+b: r_nota=0, r_notb=0, r_cin=0, r_eq=0 a-b: r_nota=0, r_notb=1, r_cin=1, r_eq=0 b-a: r_nota=1, r_notb=0, r_cin=1, r_eq=0 a=b: r_nota=1, r_notb=0, r_cin=1, r_eq=1 a!=b: r_nota=0, r_notb=1, r_cin=0, r_eq=1 a>b: r_nota=0, r_notb=1, r_cin=0, r_eq=0 a>=b: r_nota=0, r_notb=1, r_cin=1, r_eq=0 a<b: r_nota=1, r_notb=0, r_cin=0, r_eq=0 a<=b: r_nota=1, r_notb=0, r_cin=1, r_eq=0
