12 years ago --- Quote Start --- Maybe you can run that from Windows command prompt --- Quote End --- I'm not sure that the Windows command prompt will work, since it probably does not have paths setup correctly. System Console can be started from the command-line by using the Start menu to get to the "NIOS II Command Shell" (Cygwin shell) and typing system-console. Cheers, Dave
