9 years agoget_global_id(0) cause much latency ?
Hi I'm trying to compare the performance of FPGA and GPU based on image processing algorithm. I've found that there's a 10ms different when using the get_global_id(0) and not using it. The kernel ...
9 years agoYou can see the latency values by hovering your mouse over the blocks in the "System Viewer" tab of the report.
