9 years agoget_global_id(0) cause much latency ?
Hi I'm trying to compare the performance of FPGA and GPU based on image processing algorithm. I've found that there's a 10ms different when using the get_global_id(0) and not using it. The kernel ...
9 years agoThanks for the replies
I did more testing and find that if I didn't use the "reqd_work_group_size(2, 1, 1)", including "begin=get_global_id(0)"(still not using it) it would run slower then single pipeline; but when having the reqd_work_group_size attribute, including or comment out "begin=get_global_id(0)" made no difference, both slower then single pipeline. the difference are like 13ms and 1.5ms each frame. I guess it's like you said because of the pipeline length. Could you tell me where did you see the 32 and 192 cycle number? I didn't see them in the report.html Thanks
