9 years agoget_global_id(0) cause much latency ?
Hi I'm trying to compare the performance of FPGA and GPU based on image processing algorithm. I've found that there's a 10ms different when using the get_global_id(0) and not using it. The kernel ...
9 years agoI'm confused. "begin" as the work-item number is not used anywhere in the code. Is that a typo? Should it be:
int iIndx = get_global_id(0); replacing the for loop?
