10 years agoGenrating vhdl code or vhdl file from java
Hi Guys, I need to generate vhdl code from java? Is there any way to do it? below is the general behavioral component vhdl program. How do i write in java this kind of vhdl template?please he...
10 years ago --- Quote Start --- Vhdl and java are different things and converting from one to the other is not trivial. You need to understand digital logic to convert to vhdl --- Quote End --- I have a certain java file, when i run that file I get a window where i have to select component and type of component weather it is behavioral or structural component,and i have to also select states and transitions if it is behavioral and then i have to export it as vhdl after exporting it should generate .vhd file. for example the below generated file is for behavioral(fsm) .vhd file which was generated using python but i have to do in java. -- fsm for VHDL export by SpecScribe LIBRARY ieee; USE ieee.std_logic_1164.ALL; ENTITY fsm is PORT ( global_clk : IN std_logic; reset : IN std_logic; a : IN std_logic; b : IN std_logic; c : OUT std_logic); END fsm; ARCHITECTURE fsm_A OF fsm IS type fsmstatetype is ( state1, state2, state3); BEGIN fsm_P : PROCESS (reset, global_clk) VARIABLE testvariable : std_logic := '0'; VARIABLE fsmstate : fsmstatetype:= state1; BEGIN IF (reset = '1') THEN testvariable:= '0'; fsmstate := state1; ELSIF (global_clk'event and global_clk = '1') THEN CASE fsmstate IS WHEN state1 => IF (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state2; ELSE fsmstate := state1; END IF; WHEN state2 => IF (a='1') THEN and (b='1') THEN testvariable := '0'; fsmstate := state3; ELSE fsmstate := state2; END IF; WHEN state3 => IF not (a='1') THEN and not (b='1') THEN testvariable := '1'; fsmstate := state1; ELSE fsmstate := state3; END IF; END CASE; END IF; c <= testvariable; END PROCESS; END fsm_A;
