14 years ago
Generics on the command line
Does anyone know of a way to pass a generic value in to my top-level VHDL design from a command-line build flow? For instance, if my top level file has
Generic (
  STAMP : integer
I'd like some way to pass STAMP = $(date +%s) to quartus_map.
Right now I'm calling quartus_sh --tcl_eval to make some set_parameter calls before calling quartus_map, but that seems really really kludgey.
    There is a "quartus_map --set" option to change QSF assignments, but I don't know if it works for Parameters. I would suggest writing a proper script instead of calling --tcl_eval:
    quartus_sh -t set_date.tcl
    where set_date.tcl will use Tcl to get the date and set it on the QSF.
    alternatively you can have the TCL modify the source code to give the value a different default value, or move it into a package and do the same thing.
