12 years ago
Generic Priority Encoder
Is there a better way to generate a generic priority encoder without IF/ELSEIF? I need the parameterize my encoder (before synthesis), without recoding manually every time. I have manually coded up a fixed priority encoder, and clearly IF/ELSEIF is less optimal than using CASE statement. But I haven't been able to keep it generic without using IF/ELSEIF. It needs to be minimal logic layers.
    --- Quote Start ---
    I couldn't find it in my altera_mf_components.vhd file, but I instantiated it anyway and it seems to work. Maybe it's been moved to another file?
    --- Quote End ---
    The VHDL component definition is in quartus\libraries\vhdl\altera_mf\altera_mf_components.vhd, for all Quartus versions since V7 at least.
    Altera is using it in many arithmetic MegaFunctions internally, for some reason, they didn't document the function.
    component altpriority_encoder
       generic (
          lsb_priority   :  string := "NO";
          pipeline :  natural := 0;
          width :  natural;
          widthad  :  natural;
          lpm_hint :  string := "UNUSED";
          lpm_type :  string := "altpriority_encoder"
       port(
          aclr  :  in std_logic := '0';
          clk_en   :  in std_logic := '1';
          clock :  in std_logic := '0';
          data  :  in std_logic_vector(width-1 downto 0);
          q  :  out std_logic_vector(widthad-1 downto 0);
          zero  :  out std_logic
    end component;
    --- Quote Start ---
    My design ideally would be able to run in excess of 333 MHz which might not be realistic.
    --- Quote End ---
    With how many pipeline (register) levels? Which FPGA family? You have already 2 register levels (in- and output registers) in your example code.
    Is this function not supported in ModelSim?? When I compile the altera_mf, I don't see it in the library. Any thoughts?
    --- Quote Start ---
    --- Quote End ---
    I found it here:
    \altera\quartus\libraries\vhdl\altera_mf
    --- Quote Start ---
    --- Quote End ---
    There is probably no functional simulation model. altpriority_encoder is used internally in the synthesis of several arithmetic MegaFunctions, but apperently not in the respective simulation models.
    But what's the point of simulating altpriority_encoder? For the functional simulation you can replace it by a simple behavioral model as suggested previously in this thread. If you are interested in timing behaviour, you'll refer to gate level simulation.
    Any MegaFunction should have an associated model. The priority encoder is simple enough to generate my own behavioral model, but I shouldn't have to if it's an Altera IP. I'm also not simulating just the encoder by itself, it's of course a part of a much larger system model, and it will be used many times all with different input parameters. I don't really want to get involved in the gate level stuff until I get a functional model working, it just slows down the work flow. Thanks.
