gflood
3 years agogeneric fpga HAL driver API source code availability
Hi guys,
i'm a newbie to this frum and am not really sure if this is he place for this...
does anyone know if the intel_gsfi source code is avaible for download for intel projects...
* 1. O...
KellyJialin_Goh
3 years agoHi,
Do check out this link to enable the GSFI HAL API: https://www.intel.com/content/www/us/en/docs/programmable/683419/21-2-20-1-1/nios-ii-hal-driver.html
You will need to Enable altera_safeclib in BSP Software Package from BSP Editor to use the HAL API.
1.To enable the altera_safeclib, these are the GSFI IP parameters that you will need to set with the photo attached below.
2.Regenerate the .sopcinfo file and you should be able to see the altera_safeclib on the software package.
Thank you.
Kelly Jialin, GOH
- KellyJialin_Goh3 years ago
Here is the parameters that you will need to set for the GSFI IP to allow the altera_safeclib.
Thank you.
Kelly
