13 years ago --- Quote Start --- No, the error was because the component MAC get its value from another entity, a top-level one. --- Quote End --- Ok, you didn't put the generic map on the component when you instantiated it. It sounds like you've got things sorted out now. Note that if you have a generic (or a port) that would normally take on a specific value, then in your component definition, you can supply a value, and then that value will be used if you do not list that generic (or port) in the generic map. Cheers, Dave
