13 years ago --- Quote Start --- Value of width is provided by another entity. --- Quote End --- Right, but the error was because the component MAC did not have a value set. --- Quote Start --- I didn't knew i have to set the top level entity. --- Quote End --- Ah, I see, you accidentally had MAC as the top-level component. I have got into the habit of putting default values in the entity/architecture file so that I can run a synthesis check, and then deleting them on the component definition in a package, so that I don't forget to put the generics on the component when I instantiate it. Cheers, Dave
