Generation of HDL failed in quartus platform designer
Hi all,
when I tried to integrate a custom RTL in platform designer and try to generate HDL . I encountered this error.
Error: SoC1: connection (post-transform) is missing a start point: null->nios2_gen2_0_custom_instruction_master_multi_slave_translator0.ci_slave
Error: Internal Error : Cannot generate a system with dangling connections.
My custom RTL will make use of nios custom master interface which was packed properly without any errors and connected properly without issues. but getting above problem while generating HDL. I tried removing dangling connections but that option was disabled and greyed out in GUI.
Any help on this.
Thanks & regards,
Anil
- KhaiChein_Y_Intel
Hi Anil,
Which software edition (Pro/Standard) and version you are using? Could you share the design and steps to reproduce the error?
KhaiY
- KhaiChein_Y_Intel
Could you share the design file for investigation?
KhaiY
- anilinintel
Quartus version: Quartus Prime Version 18.1.2 Build 277 02/12/2019 SJ Pro Edition
patches installed: Nonemachine : Red Hat Enterprose linux server 7.3 (maipo)
Design details : it's nothing, just a nios, jtag uart, ocm of 256 KB and custom RTL file . we reproduced this error in this smaller design.
custom RTL file : it's a small RAM block with an Avalon interface and also have a custom slave interface IO ports like AVLN_RST,AVLN_CLK, AVLN_EXISTS, AVLN_DATA0, AVLN_DATA1 ,
AVLN_EXISTS, AVLN_MDATA. This single RTL file was packed well and integrated (in platform designer gui) with nios master ports and custom master interface.
And while clicking on the generation of HDL after system integrity validation. we end up with the error shown in the original post. we suspect of something like license issue which ended on 25-sept.
Is it that?regards,
Anil
- KhaiChein_Y_Intel
Hi Anil,
Could you share the test case and steps to reproduce the error?
KhaiY
- KhaiChein_Y_Intel
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
