14 years agoFor various reasons I need to use individual executables (that's how our build scripts are structured) rather than "quartus_sh --flow compile".
It looks like using the following parameters to quartus_eda: --read_settings_files=off --write_settings_files=off <proj> -c <version> --format=verilog --tool=modelsim --simulation=on fixes the problem. GUI flow was using the command: quartus_eda --read_settings_files=off --write_settings_files=off <proj> -c <version> So by adding format, tool and simulation parameters to command line, even though the QSF already contained those options, made it work. That sounds like a bug. Thanks, Evgeni
