16 years agoIt should work. Are you sure you are generating the compressed .sof file? In Quartus go to Assignments->Settings... click on the "Device and Pin Options..." button. If you go to the Configuration tab and check the box next to "Generate compressed bitstreams" (also make sure the other settings are correct).
