9 years agoGenerating JAM file
I would like to program a MAX V device using STAPL. I intend to run JAM player in an embedded processor. Is there a trick to generating the jam or jbc file? The "Create JAM, JBC, SVF or ISC File..." ...
9 years agoHi Martin,
Thank you. It works now. I did not realize that "Create JAM..." could be found in the programmer file menu. I looked in the Quartus file menu where it also can be found but it is always disabled.
