16 years agocounters or state machines can do that readily. Delay units will be in clk periods. You can also use the two clk edges then combine the results allowing you half clk period units.
If you want other delay units unrelated to clk then that technlogy is not available yet in fpgas. For example you can use Tco of registers or combinatorial delays but all are unpredictable.
