tedh4ddv
3 years agoGenerated clock constraint - not a pll or mux clock
I need to double the frequency of a clock, but the source is not a clock pin, so I am unable to use a PLL. I opted to use a shift-register and exclusive-OR gate, instead. Should the high-speed cloc...
SyafieqS
3 years agoIn this scenario, the constraint's 'SOURCE' should be set to the high-speed clock (hs_clk) driving the shift-register.
This is because the frequency of the high-speed clock (hs_clk) and the number of stages in the shift-register both affect the frequency of the clock that is being multiplied (clk_in). The output frequency (clk_in) will increase when the shift-register and XOR gate are used to double the frequency of hs_clk. The high-speed clock driving the shift-register must therefore be correctly restricted when the clock network is constrained, and the constraints must also take into account the frequency of clk_in that results.
