12 years ago --- Quote Start --- if I wanted to check that an Altera Avalon-MM slave component worked correctly, I would use the Avalon-MM verification IP suite to test it --- Quote End --- That sounds not so weird indeed. The interface should be able to be tested without knowing what the exact component does. But I would never know if the answer the component supplies is of any logical value, unless I have written the design myself and know when it should give output y with input x. Thats where I was thinking. --- Quote Start --- Any how do you tell if the component isn't doing the right thing if you do not test it? --- Quote End --- That was the line where I was thinking about when I can start thinking about that testbench. Since I am still a bit stuck to design the thing itself, I cannot write a testbench yet. Because than I would have to know the exact design and think about how to define my generated design works. How weird is it that I am thinking about using another language to read the entity inputs and outputs to know which ones I need to put in my toplevel? So at that point I know which files i need to include, so I also know which entities. But I don't know which inputs and outputs the entity has and how can I connect this component if I don't know the in or outputs? Or am I overseeing some features of VHDL? In my understandings I can use the generates when I already have instantiated the components and the same with configurations.
