12 years ago --- Quote Start --- You can never assume anything --- Quote End --- I just meant to say, that I don't have the information about what this exact component should do. So I assume, that whatever he does, is supposed to work. At least for now, to keep things simple. Later on I could think about: but wait, what if this component isn't doing the right thing, I must at least tell the user it will not work. Now my biggest problem is to find a way to connect those different blocks to the right signals. Since my blocks aren't as similiar as I thought at first, which means I am not able to use configurations. The blocks have a different amout of inputs and outputs. I was hoping I could make some template and just fill in the right words in the right places(that will probably be done in an other language). But for now I think the design is to complex for such a solution. So the step creating the synthasizable HDL isn't as far as I thought it would be yet, or maybe even the basic design.
